Plastic shims used to align vibrating equipment
Any feedback on experieces and suitable plastic materials to use for shims when aligning vibrating equipment. The shims would be 50mm x 50mm, 1,2,3mm thick in large quantites. The intention is to save cost, the current shim material is stainless steel.
RE: Plastic shims used to align vibrating equipment
