aisi 1005-1012 bar or seamless tubing/pipe
Good day:
I am having trouble finding this material. The US Navy is specifying this material for use with a seal ring.
Are any of these low carbon steels available in bar or seamless pipe/tubing.
The finished sizes are approx. 4.5" OD x 4" ID and 3.5" OD x 3" ID. The specification states AISI 1005-1010 annealed to 55 HRB max.
If these materials are truly not available, then we'll need to go to the Navy and state as such.
TIA,
TIA,
Eyke
So long and thanks for all the fish --Douglas Adams (1952-2001)
RE: aisi 1005-1012 bar or seamless tubing/pipe
(piping guys where are you?)
nick
Do you have a source for A108 bar? I tried a supplier in Dallas, but he said things were bleak AFA finding any low carbon bar.
TIA
Eyke
Eyke
Ryerson Tull
Copper & Brass Sales (Thyssen)
Reliance Steel & Aluminum
MacSteel Service Centers USA
Russel Metals Inc.
Samuel
EMJ (Earle M. Jorgensen
I am not aware of any of them carrying as-standard anything lower than grade 1018. You may want to check directly. If the quantity is sufficient, any bar mill will produce what you need.
It is more likely that you could obtain a low carbon tube in an alloy such as 1008 rather than a bar. I recommend you investigate this option further. Any of the above Service Centers carry tubing as well, and you may check with Plymouth Tube and Timken as well:
http://www.plymouth.com/Products/SearchResults/Contact/HotContact.asp?SmallestEnglishWall=0.083&SmallestMetricWall=2.108&LargestEnglishWall=0.750&LargestMetricWall=19.050&LargestEnglishOD=1.250&LargestMetricOD=31.750&SmallestEnglishOD=0.125&SmallestMetricOD=3.175&MOM=S&producttype=C&spec=ASTM%20A%20519&grade=1008&odrange=0.125%20-%201.250&wallrange=0.083%20-%200.750
http://www.timken.com/products/alloysteel/products/seamless.asp
Eyke
