AutoCAD Attributes
AutoCAD Attributes
I think the answer to this question is "no", but I'll ask anyway. Is there a way to change the order in which you are prompted for attributes? For example, let's say I have a block with 10 attributes. I want it to prompt me for values in a specific order (starting at #1 and ending at #10). It seems that the order in which the attributes were created is the order in which they prompt me for values. What if I want to add one more attribute, but want it to prompt me for the value between attribute #3 and #4 for example? Is there a way to change the promting order without recreating the all the atttributes??
Thanks!
Jason
Thanks!
Jason
RE: AutoCAD Attributes
See:
http://www.mcneel.com/autoutil.htm
