Specific Heat
Specific Heat
Specific Heat
Can anyone tell me what the specific heat of the following mixture would be?
40% Water
40% Ethylene Glycol
20% Methanol
RE: Specific Heat
From Hysys - specific heat = 112.38 kJ/kgmole C
RE: Specific Heat
Thanks SeanB!  Out of curiosity, how did you come up with that value?
RE: Specific Heat
I just ran a simulation in Hysys, using a basis of 1 kgmole/hr for flow and standard conditions ie 15 deg C and 101.3 kPa.
RE: Specific Heat
Thanks!
RE: Specific Heat
The specific heat of a mixture is simply equal to the sum of the s[ecific heats for each component x the volume fraction for each component.
The more you learn, the less you are certain of.
