Other then Barcode?
Other then Barcode?
I need to be able to track parts the only thing is I don't think I can use barcode because the rack will go into a 375 F degree oven. Can anyone Help?
RE: Other then Barcode?
-- or at least what is it like?
<nbucska@pcperipherals.com>
Is it not possible to scan barcode before and after oven step? Most of the process tracking documents I've seen usually locates the components just prior to and just after a process step. I've never seen a need for scanning a part during a process step.
TTFN
There is no need to scan barcode in the oven, but the code itself will be damaged there.
Dskarupa, if the parts are in some reasonable pattern and do not displace when in the oven, try to find a way to remember each part's location and reapply the barcode after passing the oven.
There is no reason that you can't make an oven-proof barcode. The standard laser marking system could probably do that pretty well.
375°F is not very hot, there are oven enamels that will survive that kind of temperature and more (550°F).
Even standard military IC marking ink can easily handle about 302°F
The standard barcode reader simply needs a reasonable contrast change to affect a reading of a barcode. That means that even a surface texture change, which is pretty much laser marking machine does, will give you a barcode medium.
TTFN
Balluf makes a KILLER six position dowel pin reader pack for cheap....
Chris Elston
Automation & Controls Engineer
http://www.mrplc.com
Download Sample PLC Ladder Logic Code
at MrPLC.com
You could also consider pin stamping the bar code matrix onto the part if the part can take that kind of treatment and it is large enough. It would be a lot cheaper and more reliable than laser marking. (Been there - done that! The laser marker is very expensive and takes a lot of TLC to keep operating.) If your standard bar code reader can't read the pin-stamped bar code you can get a bar-code specific vision system that is not too expensive.
How much data do you need to track? This will determine the best type of bar code.
I worked for a CRT manufacturer and we tracked the pictures tubes through all parts of the process, including through a frit oven at 450 deg F. This was done using a ceramic barcode tag. You can check out many different suppliers at http://www.barcodelabelsource.com/ceramicbarcodelabels.asp.
Rich.....
Richard Nornhold, PE
nornrich@redrose.net
