Simultaneous Drilling and Tapping in Brass
Hello Engineers!!!
I want to drill and tap simultaneously in Brass Inserts.
Is it possible using normal drill machine and any special
chucks? Please guide.
Bhavesh Dhruve
RE: Simultaneous Drilling and Tapping in Brass
Maybe you can look into screw machines:
An italian company named Buffoli has a great history of transfer machining.
Example of cut production parts:
http://www.buffoli.it/products/home_gen_us.htm
Acme-Gridley and DMG/Gildemeister are good choices, too.
i think it depends what the thickness is. you can buy "Drill-N-Tap" from J&L and probably other suppliers, there not expensive. they are only suitable for through holes. basically its a drill and half way up its a tap. so you drill through your part and then tap it in one. in my very limited experience , i used one on a turret milling m/c. i drilled through then reduced the speed and tapped through. i didnt use a tapping head , jut hand feed , when it starts to tap the tap pulls itself through. you could probably do it on an ordinary drilling m/c at a slower speed than you would normally drill that size of a hole at.
the workpiece thickness is the deciding factor.
