Pipe end and branch
Pipe end and branch
I have a pipe which is closed at one end and has a branch coming off it near the closed end. Can I treat this as a simple 90degree bend or would the 'dead end' cause noticable resistance to the flow?
Would there be resistance coefficients for this case in ASHRAE Fundamental publications?
James.
James.
RE: Pipe end and branch
Thank you both for your advice!
James
