Annealing Aly 2024T3
It anneals at  higher temps  than the other alys
But at what temp
Thanks in advance
RE: Annealing Aly 2024T3
For full anneal (to T-0 temper): 2-3 hours at a metal temperature of 775oF (413 C), followed by slow cooling at 50oF/hr to 500oF.  Faster cooling thereafter is permissible.
Thanks Ken
Yes I used 2011 for model eng heads and its apparently not the done thing
 ,,,,, so 2024 is the go
I think its the manganese and chrome which gives the 2024 the  heat resistance over the others like 2011 and suchlike
Great
These air cooled engines run at approx 400F so I didnt think 2011 would  be a prob
But apparently it is
Ken
I guess I should have asked at what temp does say,,,,,, aly 2011 start to lose its mechanical  strength
That would be considerably lower than the annealing temp I guess
And thanks heaps
You guys are very impressive on my first post
Well done
By the by, con- rods in model engines are 2024 too
MIL-HDBK-5J  METALLIC MATERIALS AND ELEMENTS FOR AEROSPACE VEHICLE STRUCTURES, a free (& huge) download at http://assist2.daps.dla.mil/quicksearch/, has data on the effect of temperature on the physical properties of Al 2024 but not 2011.  For 1000 hours exposure, the yield strength of Al 2024 is down to ~87% at 300oF and 80% at 400oF.
For a comparison of the 2 alloys, the precipitation hardening temperature (to produce the T6 temper from solutionized alloy) is 320-340oF for 2011 vs. 375oF for 2024.  Longer periods than the ~12 hour aging period (or higher temperatures) will cause overaging and loss of strength. Al 2024 has a significant advantage during long-term operation in the 300'soF, consistent with your observations.
Ken
You said for 1000 hours exposure the yield of 2024 aly is down to 80% at 400C
Does that mean its down to 80% yield immediatly the temp is 400C ????????
Thanks in advance
Not quite, yield stress = f(Temperature and time @ Temperature).
From MIL-HDBK-5J,
Figure 3.2.3.1.1(b). Effect of temperature on the tensile yield strength(Fty) of 2024-T3, T351, and 2024-T4 aluminum alloy (all products except extrusions).
[Curves are shown for 1/2, 10, 100, 1000 & 10,000 hours.]
At 400oF, yield strength as % of room T value:
1/2 hr   78%
10        76
100       70
1000     60
10,000  46
Note: these values are more accurate than in previous post where I read off monitor; these are from a printout.
Gee Thanks Ken
Well explained
