Terminal Corrosion - Sealant required
I was looking for a sealing material that is non-conductive and is both impervious to diesel and salt water. The sealant is to be used on Stainless Steel, Perspex and mild steel.
RE: Terminal Corrosion - Sealant required
For terminal protection we use Nilox dielectric grease. For the enclosures we spray with Nylac.
Sorry about the vagueness. The terminals (24VDC about 7mm diameter) are mild steel that are mounted on a Perspex block inside a stainless steel enclosure (about 25cm in diameter. However the stainless steel enclosure over time has moisture ingress which causes seawater and diesel to reach the terminals. I was originally thinking of filling the termination chamber with packing grease, but I wasn’t sure of which greases were available that were impervious to fuel attack?
The primary purposes of the grease are to keep out moisture, and prevent corrosion. Prevention of corrosion keeps the metal-to-metal contact point in a connector conducting electricity. I would try a moderate amount of silicone dielectric grease for coating terminals, like Locktite or Permatex.
Overfilling with grease can cause heat build up in some cases.
As a Marine Enginer of many years standing I now work for a Company called Metatec based in Portsmouth. This Company supplies many sealants to the Marine trade. The person to contact there is Alex Edge, their technical Manager who is a wiz kid on sealants. Tell him exactly what the application is for and I'm sure he will come up with a solution. His mobile is 07711186057 and Metatec's office No is 0239238 1382 The contact there is Barry White.
Chris Chapman
