Installation problem V5R11
I'm trying to install a copy of catia v5r11 in my Windows XP system and i have this error.
Can't run 16 bit windows program:
C:\program~/catia v5r11\setup.exe(or one of it's components)check to ensure the path and filename are correct, and that all requered libraries are available.
Some sugestions?
RE: Installation problem V5R11
CATIA V5 REV 11 is the latest that I am aware of..........Have tried to contact the poeple you bought it from....or were lucky to access a copy !.If so I am an Mechanical Engineer with 33,000 hours on V-4.2 and what like to know if you could help me aquire a copy of V5......As you most likely know it is a limited software package that is requiring Engineers to know how to operate it.........Respectfully: Andrew Griffith <airplaneandy@yahoo.com>
I don't about WinXP yet but I have installed sucessfully Catia V5.R11 under Windows 2000 & HP-UX 11.00.
Sorry,
VnPenguin
I was able to successfully install V5R11 on windows XP.
You can try getting it through www.e-donkey.com...All de best..
Sahir
