solenoid valve and controller
Dear all,
I have a solenoid valve with 220V/50Hz. Can I use a controller with on-off control relay to operate this solenoid valve?
Thank you
Thank you
RE: solenoid valve and controller
Check solenoid current and power factor agains controller data sheet corresponding values.
If exceeded, use properly sized buffer relay.
