SUMIF and conditional Question
Hello Everyone,
Product     Volume      Customer Type
40194             4,800       Bottom 70
40194             1,000       Bottom 70
40194             42       Bottom 70
40194             0       Bottom 70
40194             8,000       Middle 20
40194             0       Top 10
40196             2,000       Bottom 70
40196             42       Top 10
40233             39       Bottom 70
40233             413       Bottom 70
40233             1       Bottom 70
40233             39       Bottom 70
40233             34       Top 10
40233             8       Top 10
My problem is:
I need to sum the Volume by each Product and by customer type.
For example:
Product # 40194 - Bottom 70 = 5,842
                  Middle 20 = 8,000
                  Top 10 = 0
Product # 40196 - Bottom 70 = 2,000
                  Middle 20 = 0
                  Top 10 = 42
How can I do this with function on excel?
I do have a list of 5,000 products.
thank you
RE: SUMIF and conditional Question
Sounds like a perfect application for the Pivot Table.
TTFN
Great !!!
Thank you very much for the tip about the Pivot Table. I have not thought about it before.
It did solve my problem.
Your subject heading is perfect. Use an array function something like this:
{=Sum(If(product=40194,If(customertype=bottom70,volume,0),0))}
Note the {} braces are not typed in, but appear when the formula is entered as an array formula by pressing ctrl-shft-enter.
-JimB
