Solar Heat Gain
Solar Heat Gain
How would one go about calculating the solar heat gain through a window? What specs of the window would be needed and what formulas would be used? Additionally, besides conductive heat loss and solar heat gain what other significant types of heat transfer can be calculated for windows?
RE: Solar Heat Gain
Not an easy thing to do by hand.
TTFN
RE: Solar Heat Gain
If you're still considering your heat gain question. You may find it helpful to check out ASHRAE HANDBOOK FUNDAMENTALS or HEATING, VENTILATING, AND AIR CONDITIONING by McQUISTON for fundamental analysis methods, or as IRStuff recommends you could use a program that would give you data based on time of day. If this isn't a problem that you might consider often, a text reference should prove adequate and cost effective.
JR
RE: Solar Heat Gain
ASHRAE is an excellent starting point. The calc. is hardly insurmountable, given that spreadsheet tools are avilable.
Modern Refrig and Air Conditioning, published by Goodheart and Wilcox is an excellent starting point and affordable. It covers equipment sizing and heat loads.
