Driven Tooling Retrofit
Hi there,
We are thinking about trying to make up some driven tooling for our Mazak QT15N 1991 maybe use a small hydraulic motor driven by a seperate power pack.
just for milling a flat, slot, or drilling a hole. Obviously the m/c has no c-axis or spindle break , so we were thinking of removing the parts catcher and making up some kind of mechanical break using the parts catcher ram and m-code.we cant index the spindle, but it may still do away with some second ops. Has anyone out there done anything similar?? we also have a Gildemeister NEF CT40. any advice would be appreciated.
RE: Driven Tooling Retrofit
We had a Wasino LJ63M mill turn with 1 speed live tools. The live tools were under powered and not very rigid.
Unless you had a specific part or machining step, setting up to do this probably won’t be worth while.
Bob
Robert Setree
www.advanced-grinding.com
