Sulfur Mist Removal
Sulfur Mist Removal
I need information on the removal of sulfur mist coming from the sulfur condenser before it enters a packed bed column as the presence of the mist may reduce the bed efficiency.Will the use of Coalescing filters be a good solution to it?
sj
sj
RE: Sulfur Mist Removal
John A. Sames
President
Sulphur Experts Inc.
www.sulphurexperts.com
Thanks for your help.This is tail gas and it is fed to a bed of iron oxide which acts as a polishing unit.
I have few questions
Is the York style horizontal mist eliminator integral to condenser or is a separate unit?Could you please elaborate more on this mist eliminator (% removal, dealers, cost etc),
And also what are the Sulfur Condenser key parameters to be considered for the for minimization of S mist ?
Waiting for your reply
sj
It sounds to me like the disengaging space in the end of the condenser may not have been designed properly.
Thanks for yor reply.
Can you explain to me how disengaging space will affect the condenser performance?
sj
The mesh pad that is used in traditional SRU final condenser is horizontal - some earlier designs had 45 degree applications that were notorious for failure. The pad is York Style 326 which is a woven stainless mesh about 15cm thick.
It can be integral to the condenser in a coalescing section on the end of the condenser or it can often appear as a separate coalescing vessel (usually vertical) with a horizontal pad in the exit - here also we have seen pall rings and other types of mist elimination media) but the mesh works best.
Without the mesh we have seen losses of more than 0.5 % of the total recovery of the plant pass through as entrained S - this can essentially be eliminated with a properly applied pad.
John A. Sames
President
