U metal fire extinguishing agent
1. How much should U metal machine cuttings weigh when used to test out a new fire extinguishing agent?
2. Should a solid piece of U metal be used?
3. If a solid piece how large a piece should be used to test out the agent?
4. If a solid piece is used how do you ignite it?
5. How many times should the test be repeated to qualify a new extinguishing agent?
