Shaft material for use with one way bearings?
I am having problems with galling on a shaft which has a 4mm id One way bearing running on it. I am assuming the problem is because the material being used isn't hard enough. This part is currently being made by an out of house manufacturer and I would like to specify a new shaft material but I am having trouble finding specific information about what shaft material should be used.
I am currently thinking of 1050 steel Q&T @ 400F with the bearing surface then ground to final size. I would appreciate any assistance.
RE: Shaft material for use with one way bearings?
Usually the bearings run on a hard surface about 58Rc hardness. I do not think your 1045 stl has that hardness. Try 8620 carburized stl or 4340 nitrided. It is preferable to use 8620 stl. These bearing journals need to be ground, as you have already done so. If any questions see <http://www.bearingsandgears.com>. My e mail is ravi_14141@yahoo.com
I am sorry the website is <http://www.gearsandbearings.com>
Hardness 58 HRc, case hardened OK (effective case depth 0.8mm min), or through hardened.
Have you considered using commercially available miniature linear shafting? Depends what part of the world you are in.
Lester Milton
Telford, Shropshire, UK
I think you might want to look at some of the
Loctite products. If it is galling, you must be
having creep at the shaft and bore. Would like to
hear from others about using Loctite as a binding
agent of the bearing to the shaft.
Diamondjim : someone has just started this thread about Loctiting bearings on shafts :Thread821-64411
However, STIEBER and others make one way devices based on ball bearing sizes, as well as their other SPRAG clutch range.
I woudl assuem from the 4mm shaft size that marman has one of the needle roler types.
Lester Milton
