tying together software with scripts in windows: help.
hi.
i'm attempting to tie together a series of windows programs that are used sequentially one after the other.
(ie: 1. CAD tool & FE mesh generator, 2. Boundary Condition Specifier, 3. Analysis specifier, 4. Run Analysis, 5. Post-processer - a Tektronic Emulator .... they're all seperate software packages that need to be run one after the other, and are quite tedious)
my problem is that i need to automate some point and click commands and menu driven options within the programs as they are running.
the programs are from a commercial developer and i only have the binary exectuables available to me, so modifying the programs to have command line flags to replace the pointing and clicking is not an option.
i am a total novice to windows programming and scripting, and i am wondering what is the best way i can do this?
i do not have access to VBA. is it possible to use just VBS scripts to call non-microsoft programs sequentially and in the process automate some point and click type commands? or do i need something more powerful?
any advice?
thanks.
any advice?
thanks.
RE: tying together software with scripts in windows: help.
Otherwise see if there are keyboard shortcuts for the packages, and if such are supported then look for programs that let you execute a program and feed it keystrokes from a programmed sequence.
