Welded Hot Tap of Natural Gas Piping
Does anyone have experience or information on hot-tapping of natural gas piping? I'm specifically looking at an application that involves installing a welded branch connection (ie, welding on the pressurized gas pipe, then hole-sawing through an open ball valve).
RE: Welded Hot Tap of Natural Gas Piping
it is important to have qualified individuals conducting the work using proper equipment to ensure safety practices and procedures are adhered to.
try investigating the following website for further information:
http://www.teamindustrialservices.com/taps/default.html
good luck!
-pmover
