Import Text file into catia V5R - drafting
is there a way to import a text file into catia V5R9. I like to edit my notes in a text file and import them into catia.
RE: Import Text file into catia V5R - drafting
Copy/paste your text from your file into a text zone in your drawing.
Or Insert your text file as an OLE object with or wothout a link (Insert + Object).
Kev
Does anyone know how to use the ActivateFram Method in Catia V5R9. The help file says:
o Sub ActivateFrame( CatTextFrameType  iType)
Activates the text frame of the drawing text.
Parameters:
iType
The text frame type
Example:
This example add a rectangle frame to MyText drawing text.
 CatTextFrameType itype = catRectangle
 MyText.ActivateFrame itype
Example:
This example remove the frame to MyText drawing text.
 CatTextFrameType itype = catNone
But I cannot get the sytax correct or something because the frame never activates
here is a sample how to use text frame:
        Set tText = ThisDrawingTexts.Add(sStamp, 545, 125)
        tText.Name = "Stamp"
        dAngle = 50#
        tText.Angle = dAngle
        tText.SetFontSize 0, 0, 5#
        tText.SetFontName 0, 0, "Arial"
        tText.ActivateFrame catOblong
regards TPale
