Ensto screwless plugs and sockets
I have been advised to hot solder dip wire ends when using stranded wire in this type of retension spring plug and socket. I have occasionally experienced a problem with the spring cutting through the soldered end and the wire becoming detached. Has anybody else found this problem.
