Hardness Conversion Tables
Is there anyone out there who can point me in the right direction to access Brinell to Vickers and Rockwell hardness conversion tables for grey or ductile cast iron. Maybe through the British Foundrymens Association or its American Equivalent.
Thanks in Advance
Thanks in Advance
RE: Hardness Conversion Tables
Phil Wakeling
I know where you are coming from in your comments regarding hardness testing and indentor size applied to cast iron. Unfortunately the Japanese still measure ferrous castings with a Vickers Hardness tester and quote Vickers Hardness requirements in their specifications. For this reason I need to convert the requirement to a Brinell Hardness so the foundry making the parts can determine whether the parts conform to Spec.
