Sound proof enclosure
For an experiment that I am trying to setup, I have to fabricate a small sound proof enclosure. I thought that an enclosure using just sheets of Polystyrene foam would perform admirably. Unfortunately it is not so. Should I be using an additional barrier of sponge or some such sound absorbing material? Can someone help?
RE: Sound proof enclosure
At higher frequencies, the stiffness of the material may start to have an effect, but this is secondary.
The absorptive properties of the material have very little to do with it (except in the sense that lining the interior of the enclosure with foam would reduce the overall sound level inside the box, thus reducing the level of sound energy which could be transmitted to the outside).
Another critical point is that the enclosure must be air tight. A double glazed window is good blocker of sound, but only when it is closed!
Here's an idea for a small 'sound proof' enclosure. Line an small domestic refridgerator (one of those small beer coolers should do, although maybe not one with a glass window) with open cell foam / glass fibre mats. This should provide a nice air-tight seal, as well as degree of sound proofing. You could then construct a masonry box around it. For access, leave one side open and cover the hole by bolting several (maybe 5?) layers of 15mm gypsum board. Shouldn't cost more than 300 dollars or euros. You may find that the fridge on it's own is enough for you. Or you could place the small fridge inside a larger one (chest feezer?). If all this is too small for you, there are plenty of companies which sell larger acoustic enclosures; The kind of thing you might find on a manufacturing floor with a machine operator inside.
Hope this gives you some ideas.
M
http://supersoundproofing.com/cgi-bin/yabb/YaBB.cgi
perhaps you can find a solution for your problem.
An additionel absorbing material will not help to solf
your problem. Using wood insted of PS-foam and absorbing material at the inside is a better solution.
Tijke.
Thank you for your response.
I am afraid I cannot consider a masonary wall as the enclosure has to be movable. However, the ice box concept
is great. Going by the advice you have given, I plan to make an outer box with a couple of layers of GYP board in the cavity. I will however try and make the inner box as air tight as possible.
Any Comments?
M
