INTERNAL ERROR when printing after color change
When I select multiple entities of different colors and then change their color to white, I receive the following error: INTERNAL ERROR: !dbobji.cpp@5008: Unknown error 253
I then get booted out of AutoCAD R14. AutoCAD's help refers to this when there are problems with reading an object in the drawing database. They also say after this error the drawing will usually be corrupt. They recommend the 'Recover' command. When I open this same file on someone else's machine this does not happen. When I select objects with colors other than white, I can make the change without error; however, as soon as I select and attempt to change an object that's already white I receive the error. Thanks for any insight into this other than reinstalling.
RE: INTERNAL ERROR when printing after color change
also you might try this use the wblock command and select only the items you can see (you may want to do a zoom extents or zoom all before hand)and save that out to a new drawing and continue working out from there
if you do need recovery on that drawing my email is
sherrin@shasta.com
