Flat pattern of mirrored part?
Anyone figured out how to get a flat pattern of a mirrored part into a drawing? Or even in the model for that matter.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Flat pattern of mirrored part?
Stoker: Mirror solid body does work on sheet metal, but you must pick an edge surface as the mirror plane. Principal planes and bend surfaces can not be used, this makes mating much more complicated as the two parts can not share origin/plane information. Additionally merge bodies is required for sheet metal, so an additional cut/extrude is needed to separate the twins. It gets worse, only one flat is created for this file, the second must be manually created with configurations, derived configurations surpress/unsurpress etc. At the end of the day you have a handed sheet metal part fully associative to it's opposite hand brethren with flat patterns available for both. However no model items/dimensions, cosmetic threads or hole callouts for the mirrored part (separate bug).
Conclusion: Mirrored parts don't work yet for sheet metal, better luck next release! Our engineers could do this faster as two totally independent part files keeping up with the associative link on post-it notes.
I deal alot with sheet metal. I have never had a problem creating a sheet metal flat pattern from a mirrored part. I do as Mandrake22 suggests, and in the mirrored part I Insert>Bends.
Stoker, what advantage is there for creating mirrored parts with this method? I don't feel configurations should be used to create new parts in a production environment. Each part should have it's own file.
Wanna Tip? FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
Yep. Somehow the bends suppression state got flipped in the flat pattern config. Once that was fixed flat patterns look good. But I still can't figure out how to display, cosmetic threads and model dimensions, without which this function is useless to us.
The only time I use mirrored parts is when the parts are truely mirrors of another part, being identical in every aspect except for the direction of bends/features. I know people that use a mirror part as the basis of a simliar but entirely different part. They hack bits off here, add chunks there... that's not a good practice.
