Engineering software use
For quite a number of years, we have used AutoCAD (R10, R11, R14, LT) to create all of our engineering documentation. Currently, as in the past, we only use AutoCAD as an "electronic drafting table". In simpler words, 2D drawings. A couple of years ago, we switched all of our mechanical design over to SolidWorks (98Plus thru 2001) because it easily met our needs for 3D solid modeling, product design and detailing for the mechanical components (structure) of our products.
We have found that SolidWorks is not the most efficient software for creating some types of documentation. Because of this, we are still using AutoCAD for the following types of documentation:
Signage (Decals & Signs) and placement.
Schematics (Electrical & Hydraulics)
Instructions (Installation & Assembly)
Control box assemblies & wiring diagrams.
With the sales of AutoCAD R14 on it's way out the door, (and upgradability soon to follow) we are at a point where we need to decide if we are going to upgrade to AutoCAD 2000, migrate (downgrade) to a less expensive AutoCAD 2000 LT, continue using AutoCAD without any further upgrade, or purchase new software to more effectively create and manage these types of engineering documents.
What I would like to do is ask what types of software you use to create the types of documents in the list above. I am looking to identify what software is used by companies to create various engineering documents, beyond what would normally be handled by 3D solid modeling software. If you are continuing to use SolidWorks for some (or all) of this documentation, I would like know how is it working out for you (techniques/procedures would be helpful), or if you are considering different software (if so, which one).
I am not looking for opinions on which software is better, or why. The only criticism I am interested in hearing is if you have had a genuine problem implementing a particular software for a specific task, please let me know.
Your input is appreciated.
Lenny
Lenny
RE: Engineering software use
Signage:
We don't use plaques or "hard" signs. We do use lots of labels on our products, and hard plagues would be the same.
We model the label as a flat, very thin part. We show that part in the drawing and then use the drawing annotation text (note) to "design" the test height and location. The 2D drawing then controls everything. If we really, and I mean really, need to see the text in an assembly, (or are doing engraving--on a plague) then we model the test using the sketch text function and extrude a cut into the thin label/plague--the depth of the engraving. We could do this for everything, but the sketch text function is more cumbersome than the annotation note and increases file size immensly with little benefit. The part and drawing are saved with the correct part number. When we wrap the label around a cylinder, so it's location shows in an assembly, we create a new label part that has the curvature and is again really thin. We do not save this label with any sort of part number or revision control. We also tried just sketching the entire label in a SWX drawing (same method as ACAD), but then we can't insert the label with the correct part number in the assembly so it appears in the BOM. (Even for the cylindrical label, we insert the partnumbered label, but then hide the compenent).
CONCLUSION: SolidWorks is fine for signage.
Schematics:
During SWX 2000, we still used CrashKEY to do electrical schematics. We DXF'd our parts and imported to CadKey to show the wiring around it. Big pain. The 2D sketch on a drawing was too difficult to constrain for "pure" schematics in SWX also. Now that VISIO can be imported into a SWX drawing (SWX 2K1), we are looking into using VISIO and dumping CADKey. If you do lots of wire routing, you may want to look into Embassy/Works (http://www.linius.com/products/embassyworks.htm). It has lots of functionality that you definitely pay for. So much, that we decided is was overkill for our needs and haven't tried it. VISIO does electrical and pnuematic and then some.
CONCLUSION: SolidWorks (without an add-on) stinks for schematics. Works well with VISIO assuming you "Insert, Schematic" from a SWX drawing (to get the right scale for the drawing).
Instructions:
We do instructions the same as everyone else that I know. We create the figures in SWX and insert them as objects into M$ Word to match up with the written instructions. You could go backwords... insert a Word document into SolidWorks.
CONCLUSION: A combination of SWX and MSWord is the best for instructions.
Control Box Assemblies & Wiring diagrams:
Don't have much experience here. The schematics subject probably covers this pretty well, though.
Email me if you wish to discuss this more.
--Scott Wertel
scottw@interfaceforce.com
www.interfaceforce.com
We use a small in-house add-on package that makes life with autocad2000 in a 3D environment very simple. I agree that prior to AC2000 the 3D capabilities of autocad were quite limited.
Peter
I think we're getting a bit off the original subject here.
The initial question is as follows:
Thanks again,
Lenny
http://www.automationstudio.com/
however it's expensive one.
All our outside label vendors use FreeHand ver 8 thru 10 to create their artwork. This is a $300 to $400 program but I can give them files used directly into their process.
Free downloads for 30 days will give you the feel of it.
http://www.macromedia.com [free download]
http://www.sketchpad.net/freehand.htm [free tutorials]
agv
Sinage Placement: In an isometric drawing we create a label "model" in SolidWorks or we create a 2d sketch directly on the model to show placement of the sinage. This is nice because you have th eoption in SolidWorks to Hide the 2d sketch when you don't want to see it.
Schematics: In addition to creating our own mechanical parts and assemblies, we design our own circuit boards and harnesses. These are still done in AutoCad or OrCad (www.orcad.com).
Instructions: These are created in MS Word, with either the AutoCad or SolidWorks drawings inserted into the text as objects.
Control box assemblies & wiring diagrams: These are created in AutoCad.
A point to ponder, SolidWorks is a great "design" tool. AutoCad is a great "documentation" tool. We like to use both for what they were made to accomplish.
"Happy the Hare at morning for she is ignorant to the Hunter's waking thoughts."
try http://www.eplan.us/
