Structural Engineering Design and Drafting Software
I am in search of Structural Engineering Design and Drafting Software. Any idea?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Structural Engineering Design and Drafting Software
Automation of Detailing( Drafting) is not that simple. It requires lots of engineer's interventions. Some packages are available, but are not that good. Siplest solution isa to write your own AutoLISP modules to work with AutoCAD. Good LUCK.
Shenoy
roynshenoy@vsnl.com
Also I came accros a program "spacegass" it is D&A program.
I would like to thank to SHENOY for the help.
Good luck with your search.
STAAD PRO ALSO DO THE SAME AS SAP2000
SAFE IS A PROGRAM FOR DESIGNING SLABS
ETABS IS A PROGRAM FOR DESIGNING FRAMES
AUTOCAD IS A GREAT PROGRAM FOR DRAFTING
Its Windows based successors are Struct-Pro and Frame Analysis & Design. These are very powerful and will run under Autocad or Intellicad. You can set up the model within the CAD environment and then perform the analysis.
If interested, they are located at http://www.eaglepoint.com/Structural/.
William Ford
sesi@mindspring.com
Spiral Engineering Services, Inc.
CV
carlosvalinhas@netcabo.pt
