Section Cutting Plane
Can anybody help me with the cutting plane problem.
How to edit or delete the cutting plane in a view once the section view is no more needed or deleted?
RE: Section Cutting Plane
Hope this helps, bye
Petr B.
Thanks for all suggestions..
I would like to know whether the cutting plane line or the letters and arrows can be configured or not. How about the detail view selection?
Petr B.
The layer setting helped to solve the problem.
Thanks to you all once again
