Unigraphics v15 on windows 2000
Has anyone had any luck installing ug 15 on a windows 2000 machine?
RE: Unigraphics v15 on windows 2000
V15 is not Windows compliant by itself. You need to be running Exceed for the Unix emulation.
I believe someone mentioned how to do this on the internal UG BBS.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I have exceed 6.1 installed.  I run setup and it get an error.  Unable to istall.
Check NT Version
The installed version V5.0 of Microsoft Windows NT software is not supported with this version of Unigraphics.
Please install WINDOWS NT V.40 certified by Unigraphics on this system.
Check out the install conference on the internal UG BBS system. Search for 'v15 under Win2k'.
It does run but you have to change the registry to fool the UG install scripts to think you are installing it on WinNT.
You will need a copy of your legal UG issued license file to obtain a WEBKEY account to get into the EDS systems.
Ben Loosli
Ingersoll-Rand
I changed HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion  changed Current version from 5.0 to 4.0 and it works.
Note install exceed into a directory with no spaces.
Install fine.
