Result in different layers?
I use the command:
*SHELL SECTION, ELSET=ALL, COMPOSITE
0.012 ,3 ,MAT1 ,ORI_FRONT
0.016 ,3 ,MAT1 ,ORI_FRONT
0.200 ,3 ,MAT2 ,ORI_FRONT
0.016 ,3 ,MAT3 ,ORI_FRONT
0.200 ,3 ,MAT4 ,ORI_FRONT
How can I view the result for different layers in the Viewer, for instance the stresses? Do I have to specify integration points or something else? Do I have to specify on my output request that I want the results in different layers?
I hope someone can help me, I'm stuck!!
/Pablo
/Pablo
RE: Result in different layers?
What you need are the different section points of the cross section. In your SHELL SECTION definition you have chosen 3 integration points per layer. So you will find 15 section points for which you can plot the results in the ABAQUS/Viewer.
To identify the section points on which ABAQUS shall store the results, you need to list them in the *ELEMENT OUTPUT option.
If you use another postprocessor than ABAQUS/Viewer, things may be different. FEMAP for instance is not (yet) able to import results on more than two section points per shell element.
Hope this will help.
Rudolf
How do I specify the different shell section points on the *ELEMENT OUTPUT keyword?
When I look at the Result>filed output>Section points at the moment I only can choose between SNEG or SPOS, I want all the other section points as well!
I hope you can help me some more.
/Pablo
1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
S,E
This will give the stresses and strains for the section points 1 to 15 (see ABAQUS Keywords Manual page 5.8-1). For the numbering of the section points refer to the ABAQUS/Standard User's Manual, Section 15.6.5.
This is how you can write it into the input file directly. I don't use ABAQUS/CAE.
This was a big help, now I know more exactly how I should do this!!
/Pablo
