Drawing Limits - Remove from View
I would like to be able to remove the drawing limits from the display, so we can do a JPG export of our drawings. Is there a switch that will turn the drawing limits off?
Chad Richardson
DARcorporation
Chad Richardson
DARcorporation
RE: Drawing Limits - Remove from View
The view borders are turned off under:
Preferences
Visualization Preferences
Names/Borders
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Chad Richardson
DARcorporation
You might want to use the Retain Dimension Display option found in the Modeling Sketcher Dialog to show your sketch dimensions in a 3d view in Model Space.
You can get depth dimensions to display by using reference curves in a separate sketch to show any depth dimensions.
Then show the sketch layers and blank the curves if you don't want them displayed.
Michael Cole
Belcan Corp AETD
