gap steel structure
gap steel structure
how many gap between connetion (flg.and nut&bolt) horizential beam and column is authorize?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: gap steel structure
The AISC has guidance for bolt spacing, edge distance for sheared and rolled edges; you also have to provide clearance so that the bolts do not interfere with impact or any type of wrenches. There are also those industrial standards used by fabricators.
I suggest you consult AISC specifications section in the manual (ASD and LRFD editions).
Good luck
