Cannot Format Drive C(Harddisk Drive)
The first,operation system of my computer is Window ME and I want to use Window 2000 with Window ME.So I install Window 2000 after Window ME but cd rom which have Window 2000 software was rupture in time of install Window 2000.In many months ago, I want to format drive C and install both operation system, Win ME and Win 2000, but I cannot format this drive.It show message "Drive C is in use by another.Formating Abort." when I format this drive.How do I do?
RE: Cannot Format Drive C(Harddisk Drive)
Your message is very difficult to interpret in detail. I understand that you want to have both Windows ME and Windows 2000 on the same system. I assume that you have already established that both can reside on the same disk peacefully. I see that you need expert advice on computers because you don't know that you should not try to format the C drive through the resident OS. I'd advise you to carry the system to a computer shop and explain them what you want and let them do it for you. This is the easiest, cheapest and surest way of getting what you want.
Good luck,
Engin
> During the boot, hit F8 to get you the boot menu and boot into console mode, which is DOS and format from there.
> The installation program should allow you to format the hard driveas part of the installation process.
> Some computers allow you to low-level format the hard drive, which takes a bit of time, but will definitely wipe the drive clean.
TTFN
Best of Luck
If using the FORMAT command after booting from the CD fails you may need to use a low-level utility such as FDISK to remove the original partition from the hard drive and create a new one. The FORMAT command may then be used to format the hard drive.
I most strongly recommend that you DO NOT use the low-level format utility built into the motherboard bios because should the bios not unlock the drive properly to low-level format it the servo guide tracks and defective cluster remapping table may be corrupted or destroyed rendering the hard drive unreliable at best or totally useless at worst (requiring manufacturer recalibration).
