Ring Joint Flange
Ring Joint Flange
I have a manifold with 5 three inch rtj flanges at 3000 psi. I'm having trouble getting the rings to seal, mainly due to bad alignment. Any ideas on how to do it without over torquing the flanges. I tried teflon coated rings but ones still leaking? Thanks for the thoughts.
RE: Ring Joint Flange
IF that's not an issue, then I'd look at using "RX" type ring gaskets. I understand they have a better seating capabilities. Check out this link below. Good Luck! ...Mark
http://www.danloc.com/StyleRx.htm
Have a good day, it's blowing pretty hard here in Houston.
Scoot911
What do you think about teflon coating a octagonal soft cast iron ring? Water's gone down, only had a 6 foot tidal surge.
S
