Truss connection to Metal Coronis Frame
Hi
I am working on a project that has a ridgid metal frame with timber truss purlins. The trusses were connected by using bolts in some locations and nailed in otheres. Both connections were to angle clips. The frame forms a gable and the trusses are run from frame to frame. Doses any one have experience in this. Thank You
WJ2K2
