Split lock washers - Any uses???
I've read through all the threads on this site and some of the reference links as well.
The general opinion is that split lock washers are of no value to prevent loosening.
My question is:
Do they have any use at all or are they just remnants from an earlier time?
I've recently joined a company where they are mandated everywhere. Before this site, I would not have questioned that practice. Now, I do. I'm just seeking all the information I can before I challenge the practice.
Again, do they have any use or any value that you know of or are they a pure waste of time, money, and inventory space?
My question is:
RE: Split lock washers - Any uses???
For lesser connections, the 'split' keeps a bit of tension on the nut to resist turning off as well as the bevel of the split is acting opposite the the nut removal.
Mechanical Engineering mag. had a very good article ~1988 or check with manufactures like Locktite.
I agree with dik (except for peening the threads, which I don't understand). For joints that require preload (tension loaded joints, joints with vibration, etc.), then split washers are useless. For joints that just need "to be there", then they may provide a little preload. I see no justification for a split washer since the cost to design, purchase, store, and assemble them cannot compete with the cost of using an appropriate preload with a standard screw.
"Recent research....suggests that this device is more effective than it appears to be. .....while this washer is flattened by bolt tension equal to only 5% of its proof load, increasing bolt preload to 70% of proof will cause the trapezoidal cross section of the washer to roll and twist down on the outside diameter, which also grows. This complex action results in a washer spring rate which can approach 65% of the spring rate of the fastener. That spring rate will dominate the behavior of the fastener under load, and will reduce the amount of preload lost under a given applied load."
Only if the bolts are finger tight or snug, then I peen the threads to keep the nuts from working loose.
All - I've seen Bickford's book referenced several times. Do you think it's worth the $150? (Dekker's got some great titles but man are they expensive).
So, the principle is that the split ring washers can be used to maintain pressure despite some minor creep of the bolted material. This condition might also apply when bolted connections are heated.
Any comments?
Ken
Why do you use a split ring washer rather than a conical spring washer? The conical washers (aka Belleville) are very common, and can be designed with just about any force-displacement relationship you could want. Plus, they have uniform circumferential pressure instead of the non-uniform pressure of the split ring washer. This would be a better engineering solution, in my opinion.
Binary,
I don't recommend Bickford's book - he is the editor of a better one that includes most of the info from his book. Read FAQ725-600 for more information.
"Plain nut, with or without tooth-type lock washer" - Relative number of cycles required to shake nut from bolt was one.
Ken, CoryPad has a good point the Belleville would be more effective retaining the preload.
The book, I would not reommend buying.
Agree, and ALCOA does recommend Belleville washers. But my application isn't so demanding, so we went with split ring+flat washer because the cost is only 1/10 that of Belleville washers.
I would like comments on use of any spring-type washers in creep-type applications (where the bolted material is intrinsically soft or may undergo heating). Seems justifiable to me.
Ken
Studies have show that the primary cause of loosening comes from sliding of the male thread inside the female threads where there is a side load. With each "slip" the thread unwinds a minute amount until it has lost preload. A split ring lock washer does nothing to prevent this movement and so does not help retain the preload. Other products such as thread locking adhesives and plastic patches that prevent the movement are far more effective.
A very good reference on this subject is NASA Publication 1228 by Richard T. Barrett published in 1990. It can be ordered by calling (703) 605-6000 and asking for NTIS Order #N90-18740/2 or by going online
BHH
