Equal distribution of air flow
How do you ensure a 360 degree equal distribution to a tower shaped object when the input air supply is being fed through a square duct asymetrical to the tower from below?
Any help is appreciated.
RE: Equal distribution of air flow
You really haven't given us much information to go on here. The answer probably is "you don't", but check out http://www.airblender.com/ They may have something that will help.
