Script Routines
Script Routines
Script Routines
Does anyone have a script or a lisp routine for globally changing the color of attributes in an entire drawing? I am running R.2002
RE: Script Routines
I have just such a routine. If you would like to give it a go, let me know. It will change a single attribute property across the board to all attributes of the same name and block. You must be careful, or you will get undesired results though, such as changing the attribute value too.
