UV Protection of Polypropylene Coating
We have some above ground steel pipework with polypropylene (PP) coating in a petro-chemical plant.
Whilst the PP coating has proved to be a very robust for buried pipeline useage, we understand that it will degrade over time in sunlight.
We believe we have 2 options:
a) Strip PP off and use epoxy paint system. This will be time consuming and relatively expensive.
b) Paint or wrap PP to provide UV protection (10 to 15 year design life required).
Does anybody know of products suitable for b). They need to adhere to PP, be UV stable and preferably come in a rnage of colours?
RE: UV Protection of Polypropylene Coating
You may try some some tapes made of low insaturated butyl elastomers.A brand called Denso Butyl 20 tape is available
http://www.densona.com
Thanks for this.
You have pointed me in the right direction.
DJ Wright
There are UV stabilizers for polypropylene. They can usually be dispersed in a solution and then painted on. Carbon black is a useful UV stabilizer. It blocks UV.
Here's an organic one:
http://www.mayzo.com/UVStabilizer.htm
