ASTM standard for PT Bar diameters > 1-3/8"
All,
Is there a ASTM standard which covers post-tension bars greater than 1-3/8"?  ASTM A722 covers bars only up to that dimension.  Has anyone else had experience with specifying bars that are larger than the 1-3/8"?
RE: ASTM standard for PT Bar diameters > 1-3/8"
Qshake,
you may with to check you date of ASTM A722. i think the lastest standard mentions up to 2 1/2". also see WILLIAMS FORM and DYWIDAG for details.
i have personally used 1 3/4" grade 150 ksi, and 2 1/2" grade 75, the latter not being prestressed, but basically high strength rebar will all-threads.
regards,
mark
Mark Geoghegan
S T R U C T U R A L   T E C H
Australia  -  Guam  -  Hawaii
