Uses for "Waste Heat"?
I have a glass melting furnace which burns approximately 1GPH of waste oil, which is rated @ 140,000BTU per gallon. Anyway, I'd like to use the exhaust heat for "something". The flue temp is 1200-1300 deg f. I figure heating air and/or water would be relatively simple using heat exchangers. What about generating electricity? Would a steam engine be the way to do it? Would it even be worthwhile? Any ideas?
Just wondering...
Just wondering...
RE: Uses for "Waste Heat"?
To find out whether generation of electricity is possible I would like to know the amount and the temperature of flue gases after glas melting furnes (Waste Heat).
Further parameters needed are
Flue gas pressure and
the flue gas temperature after waste heat use (environmental rules?).
I don't have a way to check anything besides the temp. I should probably just recover as much heat as simply and cheaply as possible. It would probably be enough to keep me toasty in the winter and keep the water hot too.
If I guesstimated my flow at 25-50 cfm and a temp of 1300f would that be worth the effort of trying to get electricty considering it does run 24/7? How many kilowatt-hours could I expect, maybe? The pressure isn't very high, the burner is only using a 100cfm squirrel cage blower. What type of equipment would I use, a steam engine/generator?
1. Even a simple steam system requires a great deal of expensive equipment.
2. What are you going to do with the power? If you can't use it internally you will have to export it to the grid. This is not something that transmission companies take lightly.
3. The electrical equipment required to synchronize a generator is expensive.
4. All the steam equipment would fall into a pressure class that requires continuous monitoring by certified steam engineers.
5. etc.
I would stck to hot water heating.
tim
rmw
There's other options but for the amount of energy we are talking about, I doubt they would be economical.
Glenn
Not at a gallon per hour.
PS If I sound crazy, it's okay I'm an artist...
Try a downdraft gasifier (+ 85% Eff.), 0% XSAir, "flue contents" hooked directly to the intake manifold of an engine, NO GASOLINE involved!
I'm producing 20KwE AND 150KwH per hour on a very simple wood chip driven system (Used oil can also be used).
The 20KwE is from an AC Generator hooked to the crankshaft.
The 150KwH is from the waterjacket of the engine (Chev 350)
The hot water is piped to other buildings via underground plastic pipe in a "hydronic heating system" arangement.
Total cost of implementation under $9,000.00 Return on Investment payback (for where I live, very cold witers) less than 3 years, total recovery of investlemt.
Total cost of dayly operation: (Free)
Intrested ?? simply reply....
Greg,
Called "Mr. Fusion" by the Locals :)
I'm very interested in your method. I've never heard of the technology you are using so I don't know what questions to begin asking. Except, how do you connect the flue to the engine's intake? Does the engine's intake create a vacuum once it gets going? Also, how many hours does the engine go between rebuilds? Where are you located?
Thank you,
Glenn Randle
I googled "downdraft gasifier" and read a bit. Are you saying that I can route the exhaust gas from my glass furnace (which is fired by waste oil) into a downdraft gasifier and then into an engine? Or are you saying I could run an engine and my glass furnace with some other type of arangement?
You understand that my primary goal is to melt glass (up to 2300 deg f) and my secondary goal is to utilize the waste heat from the exhaust for electricty and/or space and water heating. Are you saying that I can do both utilizing the same energy? I'd love to hear that it can be done, but it seems like I can only get the engine turning a generator and the hot water from cooling the engine.
Glenn Randle
Wow, I didn't expect such a quick reply, Anyhow, let me bend your ear a bit more.
In order to understand "gasification" I can give you some links, I can do alot of typing, I can show you pictures of ours, BUT, here's the thing, that takes much of what spare time I have, don't get me wrong, I'm not saying i won't help, I'm saying I'll help somewhat, OK ??
first off, http://www.gengas.nu/byggbes/index.shtml is a site (the first one I stumbled accross 4 years ago) remember this, it's crude, that is it, BUT it does work, there are many "refined" systems in use around the world, (I like to think that my system is in this catagory, but some might differ on that :):):) that one would think where built by a big mfg. or such, however, most are built by people like us, "Tinkerers", it would be wise to know how to weld, plumb, electrical, etc. before even considering my suggestion as it does get quite involved...
another site: http://www.fluidynenz.250x.com/ is an aquantance of mine, we talk now and then, he is into larger process stuff, not the little stuff I'm into, BUT, his site has tons of great info on all of this.
The entire key to making this work is this, Understanding What gasification really is... don't worry about heat exchanging at this time, keep your glass furnace the way it is for now, just get a good handle on gasification.
I'll be happy to talk here, in private OR, once the wife finishes or website, I'll post the link, however that might be a month or so.
as I said before, get a handle on what this process is, then we will continue.
Oh, BTW, in google, or your favorate search engine,
gengas
wood gas
producer gas
downdraft
gasifier
gasification
are some great words to start with.
Greg,
Now that we have that stright, Yes, I understand you primary is glass, it's the waste heat you want to utilize and that I also understand.
here's the thing, that waste heat, could be from another heating source, in leau of your current heating system (more on this later, after you understand gasifiaction, OK?? )
anyhow, get up to speed, I'll watch this post, so simply reply once you understand a bit more on gasification.
Oh, one more site:
http://www.fao.org/docrep/t0512e/T0512e00.htm#Cont...
Really Technical, BUT GREAT INFO !!!
Greg,
I've been checking out the sites you listed and think wood gas sounds great. But I haven't seen anything about gasifying waste oil. I can't figure out what good this info is to me. I've got my hands full dealing with the waste oil furnace, I wouldn't get anything done if I began gasifying wood too. I wish someone offered a stirling engine that I could couple to a generator, that seems to make the most sense, considering I already have a steady heat source.
Glenn
Good luck.
rmw
I don't understand your deal is with the cup of coffee and three light bulbs. 1300 degrees at 40 cfm is a bit more energy than that. It's probably not worth trying to get anything mechanical working, but I'm sure it would heat a lot of air and/or water, at least enough for a good size house. I could open a coffee shop, you seem to like coffee.
I like to think about alternative ways of doing things. I think it's part of my creative nature. Without creative thinking people nothing would have ever been invented. Of course plenty of "worthless" things dance around in my head but that's where the good ideas come from too.
Btw, do you think the SUV's are going to drink all of the gas before we destroy the world, or afterwards? Guess it might depend on the outcome in Florida again!
Glenn
I should clarify myself,
1) The entire process of gasification, is suted to many feedstocks, wood, coal, straw, grain, oil, etc. it's not just wood based.
2) The methods of each feedstock differ somewhat (some are better in an updraft unit, others in fluidized bed.
3) It was just a thought, as heat is still paramount in gasification, driving an IC engine is a secondary process.
Guess I'm "Jumping the gun" as I look at it, "waste oil" will shortly be a thing of the past. (perdiction is less than 10 years).
Greg
Greg,
I think gasification is a great fuel source. It uses waste products which might otherwise either just be dumped and decay, or be ineffeciently burned for heat. I'm still interested in gasifying oil but just haven't seen anything about oil yet. I've been needing to get a standby generator anyway for powering the house and shop since we have frequent outages here in the mountains.
I hear what you're saying about oil's days are numbered, but it's the fuel I'm already working with and I can switch to wood later if I need to. There's a lot of logging here but I'm not set up to handle a lot of wood right now. How much wood does your system consume? And how many hours between overhauls?
I'm looking forward to seeing your website when it's up, keep me posted on it. Also I noticed that you where looking for burner systems for you wood gas. You said that everything you'd found was for nat or propane. Why won't wood gas work with those types of burners? Charles A Hones Co has a multitube of burner designs that you should check out, they are for propane & nat but you might pick up an idea or two there.
Glenn
Oil is being gasified, however, only in the crude form, I would guess that the same principals apply, and yes they are different from wood.
My system basicly has 3 "speeds" at this time, as we have had to move back to a "co-combustor" unit due to feedstock problems with the engine fired unit, I'm still wanting to go that route, but winter, the store of chips we have are way to wet to deal with now (should have covered them ;)
The co-combustor version uses anywhere from 8-20kg/hr (about 17-43lbs/hr) not quite a turndown ratio of 3 to one.
The engine based unit runs 20-50kg/hr (43-110lbs/hr).
Both gasifiers work nicely, it's the feedstock problem that we have to deal with (I guess I could go purchase dry woodchips, but that would offset what we are trying to do), and I can use the money for a shelter for the wood chips net summer. It's too bad that in all my planing, I never thought of the excess rain we had this year.
side note: we could use the larger unit, but I would be a slave to it, trying to dry the chips to the point of being able to auger them up into the hopperbottom bin (4 ton unit), since this is not the intended "job" I wish to do this winter, we are moving back to the co-combustor, of last winter, where I know we can achive the required supply of dryer woodchips quite easyly.
Well, Now I know... cover your feedstock :)
Greg
Greg,
Just a thought. Since you're specialty is glass, it should be mentioned that borosilicate glass cylinders with graphite pistons has worked with stirling engines. Lower conductivity than metal, but it runs unlubricated & these guys mention that it saved machining time.
www.stirlingsouth.com/richard2/quadring.htm
A question on my mind is what pressure could a 4mm wall borosilicate glass tube with a ~1" bore could take. Otherwise I'd do a project like that just for fun if I had the time or justification.
