Anyone know of a spreadsheet model for air-only heat xchgr design?
Folks-
I have a recurring need to design forced-air heat exchanger electronics chasses where fans are used to move air through compartments containing plate fin arrays(e.g. Kintex fins). Except at turns, the airflow runs along the fins which are brazed in place. The airflow carries the heat away from the fins and the fins get their heat by conduction from the chassis interior. This is a single species, single phase problem so it should be much easier than most heat exchanger design problems. Any help?
Maybe a Visual Basic spreadsheet program with lookup tables for Kays and London convection correlations? A well-documented program would be just great!
Thanks in advance for helping out!
RE: Anyone know of a spreadsheet model for air-only heat xchgr design?
I've written up the correlations on CoolingZone: http://www.coolingzone.com/Guest/News/NL_March_2001/Cathy/Mar_cb_2001.html (no need to look up anything, even!) and then there's a "heat sink performance" analysis method at http://www.coolingzone.com/Guest/News/NL_MAY_2001/Cathy/May_cb_2001.html.
Cathy Biber
Biber Thermal Design
www.biberthermal.com
Best Regards,
HBJ
