Right click defaults to help
When I open a new autcad 2002 session, if I accidentally hit the right mouse button the help comes up if I have not yet issued a first command. Does anyone know how to turn off this default?
RE: Right click defaults to help
(command "redraw")
If you do not have a acad.lsp file, then create an empty acad.lsp file with this as the contents:
(defun S::STARTUP ()
(command "REDRAW")
Make sure you set the system variable ACADLSPASDOC in post R14 versions to 1.
You should not have this problem again.
Cheers.....
1) In the options setting User Preferences, Right Click Customization, select Shortcut Menu for the Default mode.
2) A little more in depth but a solution none the less. Replace the (command "Redraw") since we found out that it redraws the drawing but does not enter the command into the command list with (command "script" "redraw") then create a file called redraw.scr in the support folder and in this file enter REDRAW on the first line, make sure there are no spaces before or after it, and then one enter. If you look at the properties of the file once you save it, it should only be 8 bytes. You will see redraw pop up on the command line and the drawing will be redrawn, and redraw will be entered as the first command on the command list. So when you right click the drawing will simply redraw, and no help dialog will pop up.
Outside of this, I cannot think of anything to solve your issue right now.
too many steps to solve simple problem.
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
I once had a boss who thought it too time consuming to spend 15 minutes to create a macro and toolbar to draw a simple frame, something that everyone in the department had done for years by inserting a block, and making the minor modifications, probably only took 5 minutes to create the frame originally, but then it was prone to mistakes and inconsistencies. After writing the program, the frame drawings took 5 seconds, and there were no inconsistencies or errors. After the first three drawings, the company was saving around 2.50 per drawing, not including correction time, failed components, and rework costs in the field. It turned out that it saved the company over 10000.00 over the course of a year, that was direct bottom line profit. Was it worth the time, I certainly think so, are all projects worth the time to implement them, probably not, but if we presume a few things we can easily see how the 5 minutes to stop the help dialog from poping up can quite easily amount to a sizeable savings in time and frustration.
Consider that it takes 5 seconds to open the help dialog and then close it, this is on a pretty fast computer, I have seen some take 10 seconds just to display.
The user opens 12 drawings a day, and saves one minute every day. That is five minutes a week, that is 4 hours and 10 minutes just closing the help dialog when it is not wanted every year. I can do a heap of drawing in 4 hours.
If you implement that for 10, 20 or even 100 users it makes a sizeable difference in production.
This is just my take on it, I am personally glad that the question was posed, now I am implementing it on all of our systems in my office. It is a simple problem, with a relatively simple solution, so why not make life a tiny bit easier for those in the trenches.
"C:\Program Files\AutoCAD 2002\acad.exe" "%1" /b "REDRAW"
under folder options and now I can click on any autocad dwg and it works.
i.e.
;begin acad.lsp
(defun S::STARTUP()
;end acad.lsp
