Batch transformation in V4.2.2
Is it possible to apply a stored "move" translation to a bunch of V4 models in batch mode. Our customer would like us to transform a whole series of models to a different coordinate system and doing it manually is not an option. Any ideas?
RE: Batch transformation in V4.2.2
you have to write a little CATGEO program to do your task.
Stefan
when you don't know FORTRAN and speed isn't important, you can use IUA which is a interpreted language with many samples in the directory $CATIA/code/iua.
Stefan
no, CATIA has to be up. but I think, this is more an organisational question. You can run your IUA over night.
If you want to run it really in batch mode, you have to write a CATGEO program in FORTRAN or C, compile it and link it with the catgeo linker.
Stefan
the most important document is the:
Apllication Programming Interface Manual catap sh52-0631
Here a typical (not complete) fortran source:
PROGRAM MSGMAIN
C-------------------------------------------------
IMPLICIT NONE
INTEGER*4 IZURUE,MNUM,IER
CHARACTER*8 MODDDN,MEMBER,CPASS
C DAS IST EIN CATGEO PROGRAMM
CALL CATGEO
CALL GLOGON (PROJ,GROUP,USER,ACCT,CPASS,IER,*999)
CALL GIFALL (MEMBER,MODDDN,DISP,ICATI,IER,*999)
CALL GIMSIZ (MODDDN,EIN80,LINDEX,LDATA,IER,*999)
LINDEX = LINDEX + 100
LDATA = LDATA + 300
CALL GIMREA (MNUM,MODDDN,EIN80,LINDEX,LDATA,IER,*999)
CALL MSGMO (IZURUE)
CALL GUSEND (INULL,IER,*999)
CALL GIFRES (MODDDN,IER,*999)
GOTO 1000
999 CONTINUE
WRITE (6,*) 'FEHLER IN msgmain'
CALL GILERR (IER)
1000 CONTINUE
END
The source name have to be in CAPITAL letters (XXX.f) in the directory were the load module should be. Compile in AIX with:
xlf -c -O XXX.f
IRIX: f77 -c -Wf,-noappend XXX.f
Here the sample of a link script:
catgeo -p msgmain.o \
msgmo.o \
csystem.o \
-o /home/prog/v4load/msgmain
Good luck
Stefan
