Inserting *.dwg file in a Word document in scale
I'm curios is it possible? I must insert a AutoCAD's
(2000i) file in exact scale into a Word 2000 document,
but don't know how :-( If someone can help...
TIA!
RE: Inserting *.dwg file in a Word document in scale
One method;  After you have changed the background in autocad to white do a copy special of the entire drawing and then insert into word or any window based word processor as paste specail.  This creates a tie between autocad and word, you can jump back and forth between them.  There are other ways depending on the desired results.  Hope this helps.
Then add trial and error into resizing the window in word to get a usable scale.
SC
For reports and fee proposals I occasionally embed drawings prepared in AutoCAD; these have been exported as *.wmf files and embedded in Word.  They are 'vector' files and not 'raster /(bitmap)'.  They have the advantage of being relativel'y small and because they are vector type, fonts don't develop 'jaggies' when you enlarge them.
My greater use of *.wmf files is for embedding small drawings in Delphi programs that I write.  Embedded as an image, the line colours are retained and line widths are controlled using plines and setting a width.
I am unaware of any method of scaling these other than trial and error.  The *.wmf file created is based on the visible display in AutoCAD.  I understand that there is a commercial program/utility that allows the size of the *.wmf file to be set and I will try to dig up the name (it was posted on one of the Delphi conferences a while back).
For scaling, the kludge that I use is to include a small 'scale bar' I use on normal full sized drawings.  Most of the drawings I prepare are 'D' size and these are often printed on 11x17 paper for convenience; the bar scale allows a quick method of guestimating distances/dimensions.
