Fuse i2t damage curves
Does anyone out there know where I could find a fuse damage curve for a Siemens 7.2kV fuse?
The info I have on it is as follows
#: 3GA2122
Voltage: 7.2kV
IN= 315A
Ia= 63kA
IMW= 1260A
We've already tried contacting Siemens but have had zero success.
Any assistance with this issue is greatly appreciated
Rusk
#: 3GA2122
Voltage: 7.2kV
IN= 315A
Ia= 63kA
IMW= 1260A
Rusk
RE: Fuse i2t damage curves
If this do not work, let us know your e-mail address to send you some info publisehed on the Siemens Power Eng Guide.
http://www.eci.siemens.com/marketplaces/servlet/CoeePunchOutView?eci_command=&eci_command=CoeeConfigureProduct&sdc_m4r=&langI
d=1&cancelURL=CoeeSiemensCategoryDisplay&categoryList=2540%
2C2786%
2C2801&categoryId=2804&punchOutType=0&startPageURL=+++++++++
+++++++++++http%3A%2F%2Fconcertp01.ptd.siemens.de%2Fcocoon%
2Fdevelop%2FeptdDev%2Fprod%3Fprod_name%3DFUSES%26lang%3Den%
26country%3DZZ%26user%3D%26operation%3Dcreate%26po_type%
3Dcreate%26mlfb%3DFUSES%26payloadID%3D2003-07-09T17%253A45%
253A05.738.1810965451651354626%2540e-utilities.siemens.com%
26BuyerCookie%3DstoreId%253A1%253BlangId%253A1%
253BcountryId%253AZZ%253BserverName%253Ahttp%253A%252F%
252Fwww.eci.siemens.com%253BproductId%253A1744%
253BcatalogId%253A33%253BcategoryId%253A2804%
253BcategoryList%253A2540%252C2786%252C2801%253BcancelURL%
253ACoeeSiemensCategoryDisplay%253Bsdc_mpid%253A27%
253Bsdc_countryid%253A0%26mp_id%3D10%26mpsession_id%
3D2661147%26currency%3DEUR%26currency_supported%3DEUR%
253BUSD++++++++++++++++&sdc_mpid=27&sdc_langid=1&sdc_p=tc0s3
o1000000000014u999dp0n0l1f0m27&sdc_countryid=0&productId=174
4&sdc_rh=com.siemens.eci.cda.presentation.ECIRequestHook&eci
_new_settings=&sdc_sid=18834465693&errorView=CoeeSiemensCate
goryView&storeId=1
Is there a problem with the web page or do I need to change a setting on my internet explorer?
Could you send the power guide to rkercher@magnaiv.com
Ciao,
Rusk
