schematic for dv 59 hardinge lathe
Gents:  I need a schematic for an old hardinge dv 59 metal lathe......I want to connect a phase converter to run a 3 phase motor and run it on single phase...The motor is a 3/4 hp and is two speed....The later models of this lathe offers a speed change mechanism...this changes speed by way of pulleys, and as I mentioned the motor is 2 speed...If anyone has the same model the schematic is on the door of the electrical box....If you will provide me with your email, I will send you a picture of the physical characteristics in the electrical box of the lathe...As I mentioned, my problem is how to connect the static or rotary converter to these existing electricals,therefore the need for a schematic of model G hardinge....Thank you tools21@optonline.net
