Dimension Lines
Dimension Lines
I am enquiring about the dimension lines in SE 14.
Can anybody help me. How to create the dimension lines offset like a funnel while it is in stack up type from a common datum and the lines are too close.
Thanks in advance.
Thanks in advance.
RE: Dimension Lines
Placing Coordinate Dimensions with Jogs:
To add one or more jogs while placing a coordinate dimension, first select the element you want to dimension, then hold the ALT key and click to add the jogs.
Adding Jogs to Coordinate Dimensions:
To add a jog to an existing coordinate dimension, use the Select Tool to select a coordinate dimension,Position the cursor over the dimension line where you want to insert the jog, Hold the ALT key and Click
RE: Dimension Lines
Is there a way to modify the default settings for dimensions like prefix zero for dimensions,fonts,etc...
Thanks once again
RE: Dimension Lines
You can do this by selecting "Styles" from the "Format" pulldown. Choose "Dimension" from the "Style type" drop list. from there you can add or modify dimension styles to suit your needs.
RE: Dimension Lines
It works
