Waste Heat Recovery system
HELLO
Need some help!
I have a diesel turbine that gives 20MW.
The exhaust has a temperature on 500 degrees C
I want to use a Waste Heat Recovery system to heat up water. The steam from the water shall be led back to the turbine. Then we get a better conbustion in the turbine.
I am locking for a company that make a Waste Heat Recovery system called UREU SYSTEM. I thik that it is an german company, maby called Muneter Diesel.
Does anyone know something about this system or company.?????
Need some help!
RE: Waste Heat Recovery system
I beleive Clayton Industries is in California and the type of boiler it makes is of the flow thru type. It is an excellent boiler and very efficient but make sure you have flow controls installed to protect the coil tube from overheating in case of water flow interruption.
