Heating an oil platform Motor control center
I am looking for a solution on how to safely heat an offshore drilling Motor Contol Room. Any ideas?
The room is pressurized to keep out explosive gas. In the event of a powerloss or shutdown (in which the room is no longer pressurized) I need to heat the inside of the motor control center. The control switch is a humidistat being power by 115VAC (external source) which will switch on and off a strip heater 150-200 Watts.
I thought that using an intrinsically safe relay (such as a Warrick series 27) and a standard old humidistat would solve the issue but then I am concerned that the 115VAC heaters in an explosive environment is not such a good idea unless there is such a thing as an explosion proof strip heater.
RE: Heating an oil platform Motor control center
http://www.ruffneck.com/products/heaters.html
